Applying sealer to brick pavers
Jamesh921
James
What do you use to apply sealer to a really rough surface like brick pavers?
Sponges, mops, etc... get caught on the rough surface and leave fragments behind.
alazo1
Albert Lazo
I've never sealed brick but I suppose you can spray it on. It can be spread with a paint roller and shouldn't dislodge any particles.
boazcan
Bryan C
Solvent - airless sprayer, water-based - sprayer
Paint roller is possible, but many variables makes for differing results
FyreLyter
Steven Dillon
I grew up finishing concrete and laying brick. I also cleaned and sealed it all and prefer using a sprayer on such highly porous surfaces.
What are you sealing it with?
glenboy
GLEN
when i worked for a huge brick paving co in 1991, they were using a sprayer that needed a compressor and had a tube that went rite into the sealer can,they used a sealer that i used on mt patio called SUPER DIAMOND CLEAR i get it from a company called THEUT products in CHESTERFIELD MI 586-949-1300 www.theutproductsinc.com
James;
Since we use a solvent-based fluorochemical,
the best solution is an electric sprayer with proper TeeJet,
to get the correct coverage.
Larry
