Blower question
Askal
RIP
Al
What would the exit temperature of a 5.9 blower with an ambient air temperature of 100 degrees? Average 12hg load. no engine exhaust and no heat capture. thanks in advance.
Al Paulsen
250 and higher and would easily kill that plant if directly pointed at it.
I have hit mine with a Flir after one hour of operation and we were At 240 plus without load a few minutes after we completed the job was just trying to see if I could cool the blower down and see if it was beneficial for long time operational benefits.
Reactions: Askal
Askal
RIP
Al
more than I thought. Just contemplating what kind of plumbing material I need to go to the silencer. I have a IR camera so I will check.
dgardner
I read numbers close to that, looks more like 130-140 on my tiny phone, but keep in mind those numbers are temperature rise. Added to the 100F ambient could get you a discharge temp of 230ish. Of course I imagine the inlet air is coming from inside the house and is probably closer to 70, you'd still get a 200ish discharge temp.
Reactions: Askal
Askal
RIP
Al
this is not related to a plant kill. But I once killed a mature lace leaf maple to the tune of 1500.00.
A lot of factors come into play that a spec sheet will not show you.
I have seen the temp on the blower casing at 270 .
I think I have pics will get them up if I can find them
dgardner
I thought it went without saying that you can't just read a number off a table and hope it's exactly what you would measure in the field. The actual measurement could be higher - or lower. I assumed Al was looking for a ballpark number.
Are you saying you have seen a casting temp of 270 on a 59 blower pulling 12" hg? With normal ambient and inlet conditions? That would be unusual.
Yes inside of a box truck that has a fresh water tank radiating 160 degrees temps 4 inches from blower and the sun beating down of 50 plus feet of vac hose.
So very possible and the truckmount has worked quite a bit in those conditions over the last 17 years that way.
Reactions: SamIam and dgardner
Askal
RIP
Al
so much for plastic hose I guess. will check on metal 4" flex. Thanks for the info.
Al
