blueline champ not charging
beastystang86
I saw another thread on this with no solution. Blueline champ runs for a while then dies. Battery is newer. Cant find any info on the charging system.
beastystang86
Ok so my friend said that he ran it for 20 min. Then he shut it down for 5 min. Now it wont start.
stator?
grounds?
cables?
GeneMiller
gene miller
I'm with Dan, a good battery's not going to die that fast unless your running something else off at the same time. My little mytee pump runs the whole time so it draws. Also just because a battery is new doesn't mean it doesn't have a bad cell. I carry long battery cables just in case. Have you tried to jump it after you say the battery is dead.
Buy a meter and check to see what's really going on. It will save a lot of time and aggravation.
Gene
Reactions: dgardner
GeneMiller
gene miller
By the way Joseph, once the engine is running the battery is being charged, it's not running the engine. All the battery does is start It. The exception is when the charging system isn't working. You can use a meter or just disconnect the battery. If it starts acting strange then you've found your problem. The exception would be if you had a very large draw that exceeded both the charging system and battery. Then it would kill the engine. I doubt that's the case.
Gene
Ya its probably the alternator on the machine if the battery wont hold a charge.
What I find is the machine gets full and auto shuts off, guy just finish's a job and forgets to turn the key to the off position and it drains the battery. You need to jump it and run it to recharge the battery.
GeneMiller
gene miller
I abuse my battery with the water pump that's always running, a cooling fan that runs all day and an inverter running a compressor. I had to switch to a deep cycle. A regular battery just couldn't handle it. Still once the machine is running the battery isn't necessary.
Gene
Papa John
Lifetime Supportive Member
John Stewart
Also check the harmonic balancer.. Alternator not charging the battery was one of the warning signs that the harmonic balancer needed replacing on my TM
