Encapsulation machine
jrizo1
What is a good encapsulation machine I want to buy one but there is so many to chose from
What will you recommend?
Steve Toburen
Big Billy Yeadon says he would sleep with the new Dristar if he could. Here is an orientation video on the versatile little cutie:
http://www.youtube.com/watch?v=3Yg5TTKJCow&feature=plcp
I on the other hand am still a dyed-in-the-wool Cimex man for big commercial accounts. And Jeff Cutshall agrees.
http://sfs.jondon.com/5378/blog/encapsulation-commercial-cleaning-has-transformed-my-company
Steve Toburen
www.SFS.JonDon.com
PS Whatever high production machine you use it is essential get into encapsulation with commercial work.
Shorty
RIP
Shorty Glanville
Cimex is king in commercial.
Hoss Orbot for homes.
We have 6-Cimex's and 2- Orbots for commercial carpet cleaning. In fact Monday all our machines will be out cleaning two projects. If I were I try them out and see what you like before you buy.
Blue Monarch
Dirk Wingrove
The cimex has treated me very well. I must say tho, I wanna add an Orbot to the mix. Every so often, a certain carpet would fair better from it.
vincent
Vincent Sapp
I started out using a whittaker for encap then went to the cimex.
Cimex hands down for large commerical work. Very durable machine, absolutely nothing wrong with machine in the 7 yrs I've had it.
Mardie
Spidey said:
Cimex has saved a lot of asses
There you go again Martie, calling people names! eat yor heart out Werner
Holy shit cant i say anything without people putting a negative twist on it.
How dose this sound
Cimex has saved a lot of asses including mine.
Now if i said that i believe that the Cimex machine and encap chems have had a large part in revolutionizing the way carpet is being cleaned. Would you take that as an attack on HWE? because it is not.
Ron Werner
Ron Werner
Whittaker/Dristar can work well for encap, its lighter and easier to move around
Cimex is a brute, but once you've got it there, its easy to use and works slick!
Shorty
RIP
Shorty Glanville
jrizo1 said:
Thanks for the info
How about Duplex and brush pro.
The Duplex is very good for Flotex floor coverings, also tile & grout when you don't want to/can't break out the big beast t/m.
Brush Pro ?? no idea.
If I were purchasing a new encap machine, it would be either the Cimex, or that beast of a machine PadPrick sells ... can't remember the stupid name he gave it.
I think the Cimex is cheaper, so it'd probably be the Cimex.
I WILL be in the market soon.
How dose this sound
Mardie calm down why do always have to get so worked up ?
Some people can't take a joke and I've noticed their name is usually Marty or Martie which ever way you want to spell it.:p
j/k
:smile:
L
lust1kiddo
I tried the procaps..its similar to the jon don machine..biggest waste of money EVER. Cimex is the way to go.
Danny Strickland
level loop commercial = Cimex
short saxony = CRB
Cimex out scrubs most out there, CRB will lift pile and remove soils that the cimex won't, so match the tool to the job at hand.
you can do jobs with a CRB you can't with a cimex!!!
The Brush Pro has a more powerful motor than the other CRBs shown. It is also tested to work in up to 2" deep water meaning you can use it to agitate wet tile floor or in a rug wash pit.
Scott are the 18 inch more effetient than the 20 inch because it states the 18 brush pro (dristar 18) is a 700 watt motor and the 20 inch style we have are 800 watt motors?
carpetcleaner
I spoke to Reg Rogers, VP of Sales at Carpet Cleaner America the other day. He said that the DriStar 14 is the Brush Pro 17 and the DriStar 18 is the Brush Pro 20. Dristar uses the brush dimensions and Interlink uses the machine dimensions to name them.
Dristar 14 has a 600 watt motor which was upgraded from 550 watt
Dristar 18 has a 700 watt motor which was upgraded from 600 watt
Both of the new motors are a completely different from the old ones. They are sealed and have more "torque" to start turning easier. The old motors didn't work as well as they thought they would on our 120V electricity.
He also said that the gear system is now a better setup, he said that the gears have been a weak spot in the past.
That still means the original size setup with the 800 watt motors should be the strongest machines right?
carpetcleaner
Brush & CleanCompetitors
Pro Hybrid
45
Host
Liberator
Host
Freestyle
Host
Reliant
Whittaker
Lomac 20"
Whittaker
Lomac 15"
Lenght:20"17"15.5"12"20"15"
Width:11.2"13"12"15.5"12"12"
Height46.1"38"43"43"48"48"
Weight51.3 lbs63 lbs58 lbs32 lbs47 lbs44 lbs
Motor700W1080.77W914.5W915.5W800W800W
Brush Rotation:395 rpm430 rpm430 rpm410 rpm480 rpm480 rpm
Sound level at 0.5m:57.8 db85 db84 db75 db70 db70 db
Available brush types:445655
Dirt recover:renovatorsvacuumvacuumvacuum--
Electric Requirement:120V120V120V120V120V120V
Warranty:2 year* 5 year*1 year* 3 year*1 year* 3 year*2 year*1 year1 year
Money back guarantee:30 days-----
It appears that the 800 watt motors are the most powerful and the brushes spin faster. The more I look at CRB machines, the less I seem to know.
