Evolution glide bars
Glynn
Can you see any problem with cutting out the bracing lugs/bars in the Evo wand delrin glide ?.
Like I removed the centre screw from a PC Ti and it didn't cause any problems, so Im hoping the above may work on the Evo in an attempt to stop it continually clogging up.
GeneMiller
gene miller
I cut them out of mine and never had a problem. I also drill out the holes much larger.
Gene
truckmount girl
It depends on what kind of machine you are hooking it to. The smaller the machine, the more supports you can take out.
Take care,
Lisa
