Hard surface glide
I would probably be interested in one of those hard surface glide for an aw29. Is there a lot of overspray?
There's hardly any overspray with the devastator and all the sheer angle type wands but I haven't got around to designing the AW which has me worried due to the way the jets spray straight down We may need to make some little brass manifolds to put a shear angle on them to get it to work
Reactions: Cleanworks
The devastator looked good. The only other wand I could convert would be my pmf 802.
The PMF wand has a horrible amount of overspray and the angle of the wand is an embarrassment. You need to be 4' tall to use it effectively.
I hope you pulled it all apart and got the 10 lb of floor wax stuck to the jet manifold inside that head before you gave it back to Kona silence
