Help
GCC41
Christopher Gamboa
I have a hydromaster crossfire 4.2 The hose that connects to my water tank is not clogged but still my water tank doesnt fill and my floats do not work is there any way I can fix them
scotty747
The floats activate the valve. If your floats dont work why would you expect water? Was it filling before?
GCC41
Christopher Gamboa
I figured that I was hoping that maybe someone had an idea on how to fix them
scotty747
I replaced both mine for a couple of bucks on Amazon. Jumper 12 volts to the solenoid and see if opens and closes. Then you know the problem is the floats. Also check the quick connect. They can go bad and stay shut. And take pics of the wiring.
