How Many Steps Do You Do In Your Clean
ErikG
How Many steps do you have in your cleaning process.
I Inspect
Vacum
pretreat
spot
scrub or rotovac
rinse/ extract
Scotchgaurd hopefully
And you?
I take the call
drive to the job
get out of the van
walk to the door
greet the customer
inspect the job
talk some more
walk out to the van
get the vacuum and the spotters
go back in
vacuum and spot treat
walk back out to the van and put up the vacuum and get the prespray
walk back in
prespray first couple of rooms
get the solution hose
walk back in with the sol. hose
walk back out to get the vacuum hose and wand
walk back in with them ...
this is boring ... and we have YOU to thank for this DAT
Ron Werner
Ron Werner
measure/inspect/quote the cleaning
set up sliders and sticky tabs and set out blocks
Vacuum and move furn
set up corner guards
Prespray
Scrub with Sebo
Dwell
Rinse with GH,
spot where needed
Apply Protector if asked for
Replace furn and Post groom
Inspections, quoting, tabbing, etc are NOT cleaning steps. :roll:
Pre vacuuming, pre Spraying, scrubbing, rinsing, dobbing, are.
I'm not sure where Grooming falls as its not totally necessary for soil removal.
John Watson
Miss Wanda and I either waltz, shoddish or two step Now and again we will do a door to door!!!
Ron Werner
Ron Werner
After all those posts about grooming being part of the process unless one is a hack, and now its not necessary for the process? It doesn't do anything for soil removal, but it is part of proper application of protector, esp on cut pile.
rhyde
Portland, Oregon
rhyde
Prespray
Scrub with Sebo
Dwell
Rinse with GH,
spot where needed
Ron shouldn't yours be...
Vacuum, Vacuum
vacuum, vacuum
vacuum, vacuum
vacuum, vacuum
Vacuum, Vacuum
vacuum, vacuum
vacuum, vacuum
vacuum, vacuum
and move furn
Prespray
Scrub with Sebo
Dwell
Rinse with GH,
spot where needed
Ron Werner
Ron Werner
Vacuuming is still only One step.
Let me rephrase.
Vacuum
and move furn
Prespray
Scrub with Sebo
Dwell
Rinse with GH,
spot where needed
:wink:
rhyde
Portland, Oregon
rhyde
Larry B said:
The only step that counts is the one that has the customer telling you thanks and giving you the cash. :lol:
LOL..Isn’t that the truth
I got my first bounced check in …a long time 652.00 time to put on the brass knuckles
