Little giant question
Jesse
Is there a way to adjust the pilot light.
The pilot on our unit is normally a little small imo. Now it's tiny and I don't know what happened. Do you have any ideas as to what to check?
Thanks
KevinD
Kevin Dumas
On the face of the thermostat gas valve you will find a small cap screw and under it will be another screw to adjust the pilot light.
steve g
and if that does not work you can drill out the opening where the gas comes out. as long as the pilot stays lit, don't mess with it
K
KBRENNY
drilling out the pilot orifice can result in one extremely large pilot light flame. when my flame started getting small and going out i used a small piece of wire from a wire brush and cleaned out the hole. I have tried drilling out the hole in the past and even some of the smallest drill bits will produce a very large flame. You can also purchase a new pilot orifice from almost any propane dealer for less than a buck.
