Question For Larry Cobb
Steve Manier
Hi Larry,
I am gonna make an order from you and need to know what RX 20 and aw29 wand check valves with teflon ball and jets to get and if they will even work? Will they stop the drip? Your staff doesn't seem to know and I am clueless and you weren't availabe to ask on the phone...Thanks
Oh and is your fabric protector the same as the Impregnator...Do I have to buy them separately or can I use them the same? I thought I saw where they were the same but not sure...
they will for a little while but once the wand or RX valves start seeping threw they will start dripping again.......nothing worse then a rotary or a wand that slobbers like a St Bernard..
The cracking pressure on the check valves is so minimal that if you don't have a healthy wand or RX valves then they will drip....
your best bet is to just make sure that the wand and RX valves are in top shape...
Steve;
These are the ones for an AW29 or CMP 12" wand with TeeJets:
http://www3.cobbcarpet.com/zen3/index.php?main_page=product_info&cPath=68&products_id=4309
These are the ones for 1/8" Veejets on many TM wands:
http://www3.cobbcarpet.com/zen3/index.php?main_page=product_info&cPath=76&products_id=4781
The Ultraseal Fabric Protector can be used on Carpet, Fabric and Grout.
The Ultraseal Impregnator is best for actual stone sealing (marble, granite, etc).
It does work on Grout also.
http://www3.cobbcarpet.com/zen3/index.php?main_page=product_info&cPath=78&products_id=1215
Larry
