Van interior roof storage systems
Dwain Ray
Looking for ideas of how to store wands and tile spinners rakes brushes etc on the roof of Frankenstein (my van) please share pictures if you're using the ceiling of your van for storage
I hope to replace my rear roll up door soon with barn style doors so I’ll have that advantage of using my ceiling.
Reactions: Nomad74
Mike J
Mike Joannides
you can see the metal clips that are just screwed in, they work good for rakes and pole handle brushes. The wood took a little while to get right.
Dwain Ray
Where do you get the brights vacuum hose? How much does it cost
My hoses are custom made for me by Amflex Plastics in oceanside calif. When all said and done, they weren't very much more than blue hoses from my supplier. But i was able to get custom lengths my first and last hose on the reel are 75' and 2 middle are 50'. You can get the same green hose from Wanders in standard 50' lengths with 1 noteable difference i ordered my hoses with no black most all hoses including the neon or lime green sold by Wanders has black between the outer raised links (look at your hose and you'll see what im talking about) i specifically ordered these hoses all green NO BLACK. I had these made October 2019 i had (3) 2" 75' (3) 2" 100' (1) 1.5" 100' (1) 1.25" 100' if i remember right it was around 900.00 delivered don't quote me on that . Amflex makes the best , and longest lasting hoses, last batch i had made was in 1999 and are still in great shape on my spare truck, i have a bunch of it for sale off my 2 decommissioned vans @.75 perft but you'll have to pick it up the supply and waste hoses are standard flexzilla hoses 1/2" 5/8" & 3/4" my solution hoses are leaf or leafy green 1/4" from Wanders i bought in bulk for $1 perft and used wanders stainless steel gater ends to put um together with bend restrictors from my local supplier i do not recommend Wanders bend restrictors. Hope this is helpful. Dwaino
20191025_124536.jpg 20191025_124624.jpg 20191025_130015.jpg 20221216_130352.jpg 20200715_120358.jpg 20200103_140041.jpg 20200818_102129.jpg 20220514_122119_resized.jpg 20220723_190331.jpg 20221216_123804.jpg
Mr Brightside
Jay Wags
View attachment 121512 View attachment 121513 View attachment 121514 View attachment 121515 View attachment 121516 View attachment 121517 View attachment 121518 View attachment 121519 View attachment 121520 View attachment 121521
Beautiful thanks for the info
Willy P
Willy P
Nobody keeps their van that clean.
:eekk::eekk:. Is that a steam genie drag wand too? I have to go to the chiropractor after just looking at it. Nice set up.
Reactions: Rob Grady
Dwain Ray
Yep that's de drag wand two timin Dwaino does every carpet twice! Once with emulsifier and rx20 then following with acid rinse and a drag wand
Reactions: Mr Brightside
Willy P
Willy P
My most vivid memory of that drag wand is when I did a convent. Yikes. I got wore out pretty fast and finding the sweet spot for no chatter was a bit tricky. It did cover a lot of sf quickly.
Dwain Ray
My most vivid memory of that drag wand is when I did a convent. I got wore out pretty
It's funny , i was at a get together at a supplier in Sacramento about 5 years ago and prochem had a big simi with all their equipment for demonstration, the guy handed me a scrub wand and i musta looked really stupid because 40+ years in business and had absolutely no idea how to use it. Ive always used drag wands . The first new machine i bought was in 1979 i bought a steamgeni 733 portable, it was a 300psi 2 vacuum machine that came with a drag wand, it didn't clean very well but it dried great, so i bought a scrub wand ,i found it cleaned well but didn't dry worth a damn, so i would scrub the carpet then drag to rinse and dry. This worked great till i got employees. I found , with employees the larger the carpet the less it got cleaned. So i replaced the scrub wand with a rotary an we would clean with emulsifier, then drag with water several years later acid rinses came about and i started dragging with that, every once and awhile i run across a carpet that the drag chatters on but not too often. But every carpet i do is first cleaned and dried with rx20 then rinsed and dried with a drag wand , the drag wand is so much apart of my business it's in my logo
Oh I see.. We have bird feeders here but no humming birds..
And not much progress.. Busier than a peg leg man in a butt kicking contest..
KevinD
Kevin Dumas
Surprised the Border Patrol people haven't hit you with a cease and desist.
Dwain Ray
what do you do with the ladders?
You do windows too?
.L.T.A.
You do windows too?
.L.T.A.
Started out as a window cleaner been doin that since i was 12 at 68 not so much any more,when i had employees it was a good, now it just gets in the way ,the way i started the business was. While in the service stationed in point arena calif. i owed a friend 700.00 to make a long story short i started window washing around clearlake to pay him back, by the time i got out 20 months later i was doing 1500 a month working weekends as my business evolved so did the name
Dwain Ray
Nowadays it's Dwain Ray's Quality Carpet Care & Advanced Cleaning Services
20230318_104349.jpg 20230318_104357.jpg 20230318_104407.jpg 20230318_104415.jpg
