Water volume dropped significantly
dazzle
James
I noticed my water flow was low so I ran it for 1 min and only got 2.5 gallons from a catpump rated at 5GPM.
I tested with the hose coming off the water pump and got 4.25 G
I found the whip hose I use to mix chemical was part of the problem so I eliminated that and now am getting 3 gallons
I changed hoses that go to and from the lil giant and no improvement
the loss seems to start at the pressure regulator manifold.
I am descaling now but doubt that will help with the flow.
Not sure if it is a problem with the pump itself being it is almost 20% low on output. Could this cause the flow to be worse from resistance as it goes through the manifold and other hoses?
Or more likely a clogged up somewhere or a failing unloader sending water back to the water box
Any suggestions on where to go next?
they live
Steve
Check your QDs.
Was it a sudden loss at the wand you are concerned about?
dazzle
James
Check your QDs.
I did not notice it suddenly. I had installed a used lil giant heater and it was never giving great heat unless I was cleaning a large area. I started to notice it gradually took longer and thought it was an issue with the heater. I realized the other day my water volume seemed low so I tested it from the pump and that is when I realized the problem. I tested each hose and found that my whip/filler hose was restricted so I eliminated that and also found that two of the check valves were bad so replaced them and I am getting more volume now and far better heat. I also bought a seal kit and am going to start with the pump to make sure I am getting the 5gpm then take apart the manifold and uploader to see if there is a clog or if the uploader needs seals or completely bad. Once I am getting full flow out of the regulater manifold I will test each hose and the heater to see if there are any other restrictions.
Reactions: they live
dazzle
James
Check your QDs.
Thank you. Sorry for the late response. I did not notice a sudden loss at the wand I noticed at the machine when I was mixing chemical. I assume it was gradual because I did not notice it at the wand until I realized what was going on. I did check the QD's and hoses.
they live
Steve
Did you figure this out yet?
I had a thought and wondered if your flow to the pump was good.
Just an idea.
Or is that the whip and filler hose you mentioned?
dazzle
James
Just an idea.
flow to the pump is good. After I replaced the two check valves I get 4.5 GPM and found that two of my 50' lines were somewhat restricted so I am getting good heat and volume now. Thank you your advise it is much appreciated
