- Joined
- Aug 9, 2012
- Messages
- 11,530
- Name
- sam miller
wtf is up with the assist handle?
Are you Mexican?That’s not a swivel wand when you stand straight up and clean. Having it bent to the side helps me out.
Are you Mexican?
Never will go back to hx.
What's your experience with hx?Never will go back to hx.
Mine has been bent for years. I call it the "presidential"!Having it bent to the side helps me out.
We only want to see videos on how to clean, or look at your results, or look at your bent handle.I rarely use the 570 my tech does.
I’m on the pro 1200 mostly with a Devastator.
The video wasn’t a how to clean or look at my results or my bent handle.
It was only to show that it gets hot hot hot!
Please try harder.
Since you have a 1200. What do you think about the noise? The ones I’ve heard are LOUD.
I think the prochem Everest is one of the quietest larger slide-ins I’ve ever heard. Much quieter than my 870.
You should try it, it is more comfortable and is, I think better as far as arm position. It's a more natural movement.The side handle made me want to turn my head sideways. Lol
Too many gadgets to fail.What's your experience with hx?
Exactly.You should try it, it is more comfortable and is, I think better as far as arm position. It's a more natural movement.
Reaching for the handle parallel to the floor is not as comfortable, you don't have to turn your palm unnaturally with the assist at around1:40-2:40 oclock, it's more like a handshake.
Have youwtf is up with the assist handle?
That didn't answer my question. What is your experience, or what are the truckmounts that you've owned that've given you problems?Too many gadgets to fail.
"Grocery Baggers!"Have you
Ever tried it that way???
I also off set my handle. Makes it easier to pop up the wand at the end of the stroke.Have you
Why not? Do you stroke differently?I actually don’t offset the Devastator as per instructions of Tom.
But every other wand I own gets the twist.
My shop has 10 boxes of parts from my old hx machines. Our Hudson's (3) have 1 box with a few belts. Combined hours of about 11000 hours.Too many gadgets to fail.
CDs direct drive 450 and 470 hydramaster, Genesis and a few I don't remember. Always diverters and electronics. If my employees can't run and maintain a propane heater and an engine they are too stupid to clean carpet.That didn't answer my question. What is your experience, or what are the truckmounts that you've owned that've given you problems?
