BillC
I'm wanting to get some opinions on some slide in TM's for around $20-25K? I'm currently using a Boxxer 421 and I will be upgrading shortly so I'm wanting something a little bigger.
BillC said:I'm wanting to get some opinions on some slide in TM's for around $20-25K? I'm currently using a Boxxer 421 and I will be upgrading shortly so I'm wanting something a little bigger.
Yes to all the above. More vacuum, heat and tank capacity. I'm getting more jobs where I need to run at least 300-400ft of hose and my 421 won't handle it.Greenie said:BillC said:I'm wanting to get some opinions on some slide in TM's for around $20-25K? I'm currently using a Boxxer 421 and I will be upgrading shortly so I'm wanting something a little bigger.
My first question to you is what is it about your current unit that makes you want "more" or a "bigger" unit?
More vacuum in general?
More heat?
Tank capacity?
You get the idea, tell us what you are specifically looking for.
And while you are at it, why that particular price range?
oh...and have you made any improvements to your 421 as of yet, or is it stock?
I know who he is. Look at the bottom of my post above. I was just joking with Greenie!!packfancjh said:Uh, just so you know Greenie is the guy from Greenglides and yes he does know his stuff.
admiralclean said:Why is it that nobody who makes TM's, and also stalks the bulletin boards actually incorporates the bulletin board improvements that we all want? Do any of our favorite mfg's make rigs with 3 or 4 inch internal plumbing and 2.5 inch vac ports on their waste tanks? Are 2.5 inch hoses and glided 2 inch wands being supplied as standard equipment on anybodies packages? Are any true dual wand units being made?
They are 2.5 ready plumbed... off the manufacturing line. Hoses? Wand? GG? All accessories that can be adjusted to ones personal preference at time of purchase/ordering.
:roll: :shock: )
