Why 2 inches smaller for 175 brush?
GreenTechAgain
I know that for a 17 inch machine you should use a 15 inch brush - but does anybody know why?
Would like to use a 13 inch brush with my 13 inch machine. I want to be able to agitate tile as close as possible to cabinets, etc.
Would a 13 inch brush put too much stress on the motor?
Thanks.
Ray Burnfield
Ray Burnfield
The block will be 15". The bristles will stick out an inch around the housing.
Unless you have a riser or Pad driver.
D Rice
Ray is correct, you can use a bigger block/brush on most machines if you use a riser to keep the block below casing of the scrubber. I have a small 12" machine set up like this and having the brush a little wider than the machine does scrub edges but it can also sling solution a bit more.
Reactions: Art Kelley
GeneMiller
gene miller
I used the riser just for the reason you said. I like to be right up to the edges. All my pads are bigger than the drive block. I like bonnets to climb the baseboard a little.
Gene
