Go down to a six flow.
That is the plan Mike said to use the brush glide I need 80's on the outside and 95"s inside so I am going to do that with 1.5's. My pump is a 5gpm so I am thinking I will have a bit more impact and plenty of flushing with the 1.5 jets.
when I installed the glide the inside was hitting on both edges so it would not seat on the end. I did not notice until the fourth try and had to trim the ends. After that I notched the wand and heated the glide to get it straight and slide it back on. The leaky Glide was not Mikes fault after all it went through it did not have the tight fit it had when manufacturedYou're going to listen to him after he sold you that leaky ass glide.
Including Tom's choice to change the head/ lips 6 plus times, AND not using a internal fit designEverything is Mikes fault
What should I expect when going down to 6 flow?Go down to a six flow.
Are your jets worn out?
Vac hose plugged?
in tank filter clogged?
Something is wrong...
Why don't you measure Hg value at different hose lengths with your wand down . If I can put plastic bag over my mouth, I'm not going to be able to breathe. Your palm on vacuum intake is the plastic bag. You're suffocating your system, not testing it. If you thinking cuff are the culprit , use the barbs instead to connect hoses directly. If you see an improvement, it's a good thing.When Cool cuffs first came out I jumped on it seeing the benefits. I quickly went back to vinyl because the vacuum loss was so noticeable. I recently switched to flash cuffs and had to tighten the vacuum relief on the blower housing a lot. Now if I set my wand and hose up I get about 12" of lift but if I block the system at the tank I am above 20" HG.
Does anyone who has went from vinyl to Flash or any other cuffs have advice on getting the most out of them?
I know there are trade offs and loosing some vacuum is fine as long as I can make up for it at the relief valve but I would like to be able to get to at least 13" lift while cleaning. If it is not possible I will switch back to vinyl.
TIA
You don't have trashed carpets in CanadaUnless you are doing trashed places, a six flow should be all you need. Even a four flow will work fine on moderate soiling conditions. The more water you use, the greater the saturation of the carpet and the longer it will take to dry.
You don't have trashed carpets in Canada, I've been there once or twice. #6 flow exists in manuals only, and is used by kindergarten kids.
I'd like to know how many cleaners with bunch of commercial accounts are rely on #6 flow. I mean well, six flow on six jet wand means 01 opening per jet and that will clog jets after a few minutes of use. I'm comfortable with #10 , mixing 1.5 with 2's. The saturation shouldn't be a problem if the blower's power matches the pressure value ( 350-450 Psi), when operating with an enclosed space with two vacuum slots ( glides) that should be sufficient and yet some guys go for 550-600 psi and stil have a great drying times.
Our truck- mounts are our bread and butter, we have to make them purr, no exceptions.
Show us the after pics of that trashed carpet you just cleaned recently?
I was young and dumb once too
4 flow is all you need.
That shouldn’t have been in purple
Trashed?! lol That whole pic should be purple…
pad job.Trashed?! lol That whole pic should be purple…
pad job.
I dont go after trashed carpet at this stage in my cleaning career.
With the Chosen wand I can clean most anything I'm going to run into and have it dry in a few hours
Sold my rotary extractors too.
2 flow jets is what’s needed, not a 4flow of total flow, because 1 flow jets on a 4 or 6 jet wand is useless compared to the same tool that uses 2 flow jets
Professional corn rowing at its finestpad job.
You've been here once or twice, spoken like a true American. I use 2-4 jet wands. I have a Prochem quad with 01 jets that I use in the shop for certain rugs. Never clogs because I have a filter before the trigger valve. I have several 4 jet wands where I use .15 jets for a 6 flow. You can use whatever you want but it's pretty obvious to most people that the more water you use, the longer things will take to dry.You don't have trashed carpets in Canada, I've been there once or twice. #6 flow exists in manuals only, and is used by kindergarten kids.
I've used higher flow wands and while it's true you can move the wand a little faster, I tend to slow down on my dry passes to make sure I'm recovering enough water, negating the faster speed on the cleaning stroke. More cleaning solution usually equals more soil removal but only to a certain degree. What's the balance point? When using portables, I am down to a 3-4 flow with great results. I can't justify going past a 6 flow on the truck. I feel there is more chance of incomplete drying or wicking. Others feel differently. I know people who swear by a 12 flow.*the more water you don't recover
*the more dirty water you don't recover
I was only suffocating the system at each length to determine if I had any unnoticed air leaks. Once I knew the hoses were good I did my HG t yearsesting with the wandWhy don't you measure Hg value at different hose lengths with your wand down . If I can put plastic bag over my mouth, I'm not going to be able to breathe. Your palm on vacuum intake is the plastic bag. You're suffocating your system, not testing it. If you thinking cuff are the culprit , use the barbs instead to connect hoses directly. If you see an improvement, it's a good thing.
Fred
The other thing I should have mentioned is the new wand is a 1.5" tube. I had planned on the 2" devastator but Tom informed me that the 1.5" tube would be as effective with less effort than my 1.75" Prochem which was 6 flow.
I use mainly 1.5 inch wands. Toms is great. I do switch up to a 2 inch wand when drying times may be an issue. Doesn't help as much as people think but makes you feel better. I have one 4 jet wand set up with an 8 flow that I use on severely soiled carpet but rarely use it. Good chemistry, scrubbing when you need it and a well balanced 6 flow wand is usually all you need.The other thing I should have mentioned is the new wand is a 1.5" tube. I had planned on the 2" devastator but Tom informed me that the 1.5" tube would be as effective with less effort than my 1.75" Prochem which was 6 flow.
