charging more for wool
Walt
Assuming the carpet is lightly soiled with no specialty spotting, do you charge more for wool wall to wall carpet cleaning?
Why?
-JB-
JB
Once a cleaner gets over the fear of cleaning wool , and uses appropriate procedures, products and temperatures, it's really no different than any other broadloom.
so no.
Walt
We clean wool all the time. Most of the cleaners in our area charge significantly more for it. I've asked why and have never gotten much of an answer except liability.
I don't charge more, unless there are special needs.
Bjorn
I would charge more for a pos olefin, wool is not a big deal
on the other hand if you have to justify you 27 step totally green cleaning process
Walt
who has a 27 step cleaning process?
Pre vac
pre spray
pre scrub traffic areas with CRB (if needed)
extract
I count 3-4 steps. And yes we prevac everything including empties.
Everybody gets the same price - no extra charge for difficult stains except for paint and only then if it's bad. We don't do severe pet damage so that's not an issue.
Bjorn
some have pre and post inspection as a process and final grooming
-JB-
JB
Hey!
I wipe my feet before AND after i step on the carpets, that's two extra steps right there! :evil:
I'm Rick James
Warren Wallace said:
So then that being said do you charge more for area rugs?
Do you charge extra for synthetic area rugs?
IMO dealing with rugs is alot different than dealing with wall to wall carpets.
ACE
Mike Hughes
Liability is the only real reason to charge more. Even with proper cleaning methods the likelihood of something going very wrong is much higher they with syntactic and it’s going to cost a hell of a lot more to fix.
I have personally had every seam rip and trackless strip pop after only pre-spraying a woven wall to wall wool carpet. If someone can afford wool carpet they should be willing to pay more to have it cleaned. If not, step aside and let your competitor take the risk for $.30 a Sq Ft.
Warren Wallace
I do charge more for wool and area rugs.If you take your mercedes in for a oil change you will pay
more for an oil change, why because it cost more to replace. I charge more for area rugs in house,
but I charge the same for all area rugs.
Lefty724
E
Mikey P said:
Ohtoo worx pheenominul on wuul
Wheeew! That's what I used this weekend on a nice wool out in Carmel Valley........just making sure!
steve frasier
steve frasier
yes in a high rise condo down by the river that only has 2 small rooms of carpet on the 12th floor
Dan Lloyd
When you use Judson O2 on wool, do you use it at the regular dilution, or do you water it down a bit?
yes. water it down.
unless the carpet is a lost cause than nuke it.
Ron lippold
people pay way more for wool. I feel that if your not charging a bit more they dont feel happy.It might not be any harder to clean wool but the liability if more. I say charge if you have the balls and stand up to your work.
would you take your zo6 vette to a jiffy lube
anaroberts12
It all depends on the type of carpeting you do for your walls, wool rugs require more maintainance and cleaning so they cost more.
Regards
Steam Clean
Ken Snow
RIP
Ken Snow
People do not necc pay more for wool, and there are synthetics that run from 50 cents a sq ft to $8 a sq ft.
