Garage floor cleaning?
PrimaDonna
Megatron
MB
The salt and dirt from the roads are leaving some serious problems on garage floors. Anyone offering garage floor cleaning? Price by the sq. ft. or by the bay?
We are going to offer this as a special/promo. Will will promote on our Facebook page, but will ask every home owner if they want is to do it while we are there and offer a good rate to do it as an add on. We are already there, and won't use any product, just water.
Here is a video and some photos of us doing our shop today.
PrimaDonna
Megatron
MB
No products used, just water. Used the turbo/spinner attached to truck mount. I'll have to check with John about the water temp and pressure and get back to you.
Carl Maddock
I would use chems.
concrete going to tear up teflon much quicker
depending if floor was power troweled, or psi concrete, or many other variables as well as use will determine results.
great pics
Reactions: Lee Stockwell
Look. We don't care what color your tool is, or if it matches the hoses and is color coordinated with the flowers in the flower beds. If you are going to post here, you need to know things like psi and water temperature.
Sheese!!! :pig:
PrimaDonna
Megatron
MB
Don't get your panties in a bunch, Marty. Operations and tech stuff is not my domain. I leave that stuff to John.
Pressure was 900 PSI, temp around 230 degrees.
And it got that oil out of the concrete with NO chemicals?
Did your husband just tell you that so you'd get back in the kitchen and finish supper?
Reactions: Willy P
dgardner
Meg, do you guys do fresh water rinse on carpets or was there maybe some extraction detergent in the solution?
We've cleaned a lot of concrete. Even a minimal amount of detergent will help a lot. Jason, and I believe Justin too, did several shopping center and Kroger frontages.
i do them. easy to do and an easy up sale. prespray and then rinse with water. i never do them if they are painted because it will pop the paint. epoxy seems to take it just fine. 1100 psi. that must just be tire black cause oils not coming out.
gene
I lurk in a Power Washing board and they have a way of getting the oil out. When I get around to it, I'll ask how.
Steve Toburen
Great idea, Meg. Even though I'm a bit hurt. I'm starting to think you are not poring over every QuickTIP I send out... :)
For example, over a year ago I sent out this TIP on adding on garage floor renovation while you are there cleaning their carpets. It has some product and pricing suggestions.
PS The QuickTIP also links to a video of Big Billy Yeadon cleaning concrete. It isn't nearly as dramatic as your video, Meg.
royalkid
Gulf Coast Carpet Care
no chemicals? huh? Oil doesn't come off with just water.
knoxclean
David Gargan
I remember seeing a video Bill Yeadon made for garage floor cleaning and I also think Jon Don has a product for that as well.
PrimaDonna
Megatron
MB
Believe it or not it's not oil. That is all the dirt and road salt that stuck to the wheels/underside of the car and then melted and pooled on the floor.
We aren't opposed to using products, but we just hit this with water to see what kind of results we could get with just water. If we want to offer this as a quick add on at a decent price, we can just clean with water to remove the salt and soil (only). If there clients have oil etc that they want us to get more aggressive with, then we can upsell a deeper cleaning.
I'm going to have a hard time selling road salt removal.
They way I sell it is by wiping the floor with a white rag. Here's where all the dirts coming mam. No wonder you carpets are so dirty.
Gene
jwfoulk12
Justin Foulk
I have a customer that I clean his main upper garage about 4 times per year. Its an epoxied floor, probably 1200 sq ft. His lower garage gets done 1-2 times per year and is all ceramic tile. Oddly enough I've never cleaned any carpet in his house except for one time when he had a pipe burst.
steve_64
i just did one wednesday for $90. used some old degreaser i had laying aroung and ran it through the tank on the 175.
tried using stripping pads but they didnt hold up long so i just used an old pad driver i picked up in the fall with a bunch of other stuff. it may actually be a brush, it has pretty long stiff white bristles but it had a pad stuck to it when i got it.
then i just mopped it all up with a brown out solution. came out pretty good.
its the second one ive done this way.
