I want to take over the world
Bryce C
DFW
Connecticut
Bryce
of residential carpet cleaning in northeastern Connecticut. Have any of you guys used Go Pro cams or something similar to make quality content for social media, seo, and advertising? Have you had any success with making quality video content?
I need to paint my truck, I will when the weather cools down. I'm going for avalanche grey (the same grey on new Transits and Mustangs), hope it turns out well. I spent $1k on the paint, it better turn out well! For now I call her ugly pumpkin 😄
Reactions: Mikey P and Giorgio
Bryce C
DFW
Connecticut
Bryce
You DEFINITELY need to paint your van.
I'm not sure what is more shameful, my clean pickup truck and trailer with my weak portable doing the bucket brigade of shame in people's homes.., or the ugly pumpkin with powerful jedi extraction technology. I keep getting 5 star reviews. The common denominator may be God's grace and my lovely wife, which is more of God's grace.
Jim hooks me up with good cleaning chemistry and wisdom too. He's also part of God's grace in my life.
For now I'm just waiting for a day in the mid 70s with no jobs and no chance of rain and I'll have an avalanche grey van :]
Bryce C
DFW
Connecticut
Bryce
In one day?
Yes. I've already removed the decals and adhesives, and scuff sanded it with 400 grit. When the weather is right I will wash it (and remove waxes and oil with something like lacquer thinner) and then tape everything off which will take the first half of the day.
Then the last half of the day is 4 consecutive coats. 1st a seal coat which is like a primer but will help to conceal the bright orange. Then 3 coats of single stage avalanche grey paint. Each coat goes on consecutively while there is still some slight tack, but not too much where the paint could be disturbed by touching it. With the size of the van by the time I come around to where I began the 1st coat, the paint will likely have set and be slightly tacky so I can immediately begin my 2nd coat, and so on through the 4th and final coat.
Each coat of paint will then burn into the previous coat and all 4 coats will become 1 homogenous layer rather than 4 separate cured layers. This gives the strongest and most resilient finish.
Reactions: hogjowl
Bryce C
DFW
Connecticut
Bryce
I have a 60 gallon 5 hp air compressor, which is essential. I need to be able to compress and replenish air at least as fast as I am depleting it through the spray gun. Especially on such a large body van with no windows, and laying down the coats consecutively. I doubt I could do it with any less than a 5hp air compressor. I'll just run a long air line from my woodshop out to my driveway and go for it. My wife will be mixing up batches of paint as I am spraying to try and keep pace.
Back when I was spray finishing woodcrafts I installed this network of copper pipes to cool the air from the compressor so the 3 stage filter can effectively remove water, oil, and dirt from the air. And blow off valves at the bottom of the long copper pipes to release accumulated moisture. Which is important to get a good finish. I've never sprayed automotive paint before. I have all the pieces in place to do a good job with it. I'm the variable. I never got really great at spray finishing, but was just good enough to get B+ results most of the time. Hopefully it goes well.
Bryce C
DFW
Connecticut
Bryce
I’ve seen a few videos on YouTube where folks have rolled on Tractor paint with acceptable results.
I saw that too! I almost went that route but felt that since I already have pretty good spray capabilities with my air system, and a fair amount of experience spray finishing, that I should just go for it spraying...
Reactions: hogjowl
Dwain Ray
I've painted several vehicles. But any of my advice would be seriously out dated last vehicle i shot was with Dupont centari acrylic enamel. I would recommend that you do it in 2 stages. Shoot the roof first and when dry shoot the rest of the van. I used 3 saw horses per side with a thick wood beam as a walk way so i could shoot the whole roof at once. If you try to shoot the sides at the same time you'll probably at some point drag your hose across the fresh paint . Iwould shoot in my shop and staple cheap plastic drop clothes as a make shift spray booth and air movers as exhaust fans. Good luck
Reactions: Bryce C
Bryce C
DFW
Connecticut
Bryce
What is an oiler Dwain? As in something that adds oil? If so then no, it is a 3 stage filter system made by Devilbiss for spray finishing. The 2 small filters are designed to remove oil and dirt, and the large filter is a dessicant that removes moisture. Unless I am mistaken about something....
Dwain Ray
Just checking body and repair shops often have oilers inline i have them at my shop its the one one the bottom with the little clear bubble on top there designed to add oil to the air for air tools . In my shop i have a quick connect after the secondary dryer and before the oiler for dry air and at the bottom for oiled air. The upper quick connect is a universal so my dry air and oiled air hoses will connect but the lower (oiled air) quick connect is specific to my oiled hoses and hoses i use for dry air won't connect i require dry air for painting and bead blasting and oiled for tools. When i saw the bubbler on the top of yours i thought id ask just in case
Screenshot_20250728_082524_Gallery.jpg Screenshot_20250728_082550_Gallery.jpg
Reactions: Bryce C
Dwain Ray
Im at the shop so i can take better pictures my oiler has that little bubble on top. Compressor is 5hp 2 stage 175psi@ 19cfpm reduced to 150psi and dried to supply 3 regulated stations 2 with dry or oiled air and 1 dedicated dry/with annde second and third stage for paint
20250728_094741.jpg 20250728_094751.jpg 20250728_094349.jpg 20250728_094551.jpg 20250728_094420.jpg
Reactions: Bryce C
Bryce C
DFW
Connecticut
Bryce
Right-o. Nice setup. I don't have any air tools aside from an air hammer, but was thinking about getting some air tools soon. I imagine it will make a lot of mechanical work much easier. Is it a good idea to hook up an oiler whenever one is running air tools? Does it prolong their life or eliminate manual maintenance or something?
Mark Saiger's the master of videos. Look at his YouTube channel for inspiration.
  • Love
Reactions: Bryce C
Dwain Ray
Consider milwaukee m12 battery tools first. You have more options for use when not Tethered to a compressor. I still have a few air tools i use periodically but ive switched to battery over the past 7 or so years. I like the m12 platform because there is more options for mechanics i love there m12 fuel ratchets, cutoff tool and impact wrench. I wish i would have gone m18 for the drills though and probably soon will. The problem isn't so much the 3/8drill but the 1/2 it eats batteries. When the bit bites and stops the drill it puts a heavy load on the battery and if not careful will damage um where as the m18 is more able to take the abuse. I have everything from Sawzall, jigsaw, circular saw cutoff tool ratchets impacts borescope thermal imagine camera sodering iron drills all m12 only ones i would change is the drills.
Reactions: Bryce C
Bryce C
DFW
Connecticut
Bryce
My FB video feed got infested with carpet cleaning videos today. I’ve never seen so many horrible wand techniques and “cleaning” results.
I may not be able to target you on FB but I'll just litter threads on MB with my amateur carpet cleaning videos for you to make fun of. It will help me grow.
Bryce C
DFW
Connecticut
Bryce
That sounds sweet. Well at least in your line the m12 and m18 can be charged on the same station. I have a bunch of Rigid power tools and sometimes wish I had gotten something better from the start, feels like I am married to them. I read that Milwaukee has a lot more tool selection that Rigid, but a fair amount of folks feel that the Rigid is almost as good much of the time.
I have killed one Rigid impact wrench so far, but I used and abused it a ton. I had the bit bite and stop the drill countless times when I was first becoming handy. I am not sure how long it took as I can't remember when I first bought it. Must have been a while.
Dwain Ray
It was the 1/4&3/8 ratchets that sold me on milwaukee and the m12 platform. I originally started with dewalt and abandoned that ship when i got my first milwaukee ratchet myat present ive purchased enough batteries so as all the tools i use on a regular basis has batteries installed makes it effortless to use and i have a bank of 3 chargers with batteries in them so as not to ever be down. Only 1 of the chargers at this time will do 12s and 18s my first dip into the m18 pool will be there dual battery leaf blower. Thats easily adapted to use to dry cars and once i have that ill have the batteries and for more heavy duty or drain tools ill go that way then.
Y
Reactions: Bryce C
cape coral fl.
jack zerkie
Y
Rigid has a lifetime warranty if you register them not sure who's lifetime
Reactions: Bryce C
Bryce C
DFW
Connecticut
Bryce
Oh yea I remember registering it when I bought them, and it did say lifetime warranty, and I felt that was an odd offer on a tool like that. Would have been worth a shot if I didn't throw the impact wrench away 😄
