Need Advice coffee spill
SWass
Whitinsville, MA
Dave Wassenar
NEED ADVICE:
Customer spilled a cup of coffee on a off-white wool carpet (custom palace size VERY expensive) & I cleaned it with the usual safe products. Big improvement but still visible. They'd like to have me try some more - - they're happy to pay but I only want to go back if I bring something else to try. Been doing this 35 years & I'm somewhat knowledgeable but hey - educate me...what can I try that's safe??
NEED ADVICE:
Tannin style coffee stain remover or brown out. Apply with a coarse spray, let dwell 5-10 minutes. Rinse with a neutral or slightly acidic rinse agent. You can re-apply the tannin remover lightly and leave it to evaporate.
sassyotto
Wisconsin
Paul
40 years cleaning here and for some reason never came across coffee on wool. couple weeks back was the first time. Ordered some coffee stain remover for wool and applied it as stated above. did not do a thing.
Reactions: Mikey P and hogjowl
Hawaii
UV light helps if it's stubborn.. I haven't had a problem with multiple applications.....but it requires various trips..
Reactions: SWass
NEED ADVICE:
Are you a rug washing business or are you trying to fix this rug on site at the customer's home
Sani-Bright is big on UV
A reducer like Red Vanish may help but you have to keep an eye on it. It may pull color from a wool carpet. Let it dwell then rinse, repeat if necessary.
Reactions: SWass
Montana
NEED ADVICE:
What are your usual safe products? Can you find out more about the coffee? What kind was it? Decaf or not? Cream or sugar?
Depending on the questions above I've had good luck with Pro's Choice Stain Magic for Wool on straight back coffee. Screenshot_20250123_194732_Chrome.jpg
SWass
Whitinsville, MA
Dave Wassenar
Have you tried CTI Stain Magic for Wool?
Rick, I've used that in the distant past...it was my impression that it was the same formulation as regular Stain Magic, but with an over-priced bottle of acidic solution to go with it. I was not impressed with the results, and doubted its safety. Also VERY sudsy as I recall. But please correct me if I'm wrong...
SWass
Whitinsville, MA
Dave Wassenar
Yes, I'm planning to drop off a bottle of 3% peroxide and my UV light & invite the spiller (husband of course) to go at it carefully. UV was the only other safe thing I didn't use cuz of time constraint. I've left a light and spray bottle on site with (different) customer before & had good results. Thanks
Did not know that about decaf...
Decaffeination process often removes a lot of the natural color so they add artificial dyes to give it back that dark rich look. We also find artificial dyes in some red wines. Often the vinter can't get the color they are looking for naturally, so they add a little coloring. Usually an oxidizer will work well on red wine but if you find you are struggling with a stain, try a reducing agent and see what happens.
California
Wow lucky it didn't strip color
