Residue on Marble shower tile.
Yeah boy!
Thanks for reminding me about this one Greg.
I can only imagine they would have kicked arse.
XTREME1
RIP
Greg Crowley
I have that same shower scheduled in the beginning of november. That is why I searched marble showers
Soft scrub or grout that wasn't completely cleaned during post construction cleaning. It may be a good thing to recommend to custy a good clear semi gloss enamel heat lamp dried will protect and beautify/make it pop!!
Albert Lazo
I have the ridgid palm and the ridgid 6 inch
A palm sander should work. May get hot and need a rest after some time though. You putting a shine on it?. If yes MPs should work if it's not too bad. Even if you leave a few scratches, it won't be too noticeable in a shower. Bring some wet-dry sandpaper to take out deeper etching if it bothers you (400 , 600 grit).
XTREME1
RIP
Greg Crowley
so we have this shower that I am monkey padding what do I charge?
Larry B
Larry Burrell
Works toilet bowl cleaner would have taken care of that in 30 seconds.
Larry B
Larry Burrell
Bob Foster said:
Do you realize what toilet bowl cleaner will do to certain tiles?
Yes I do Bob. But in the other side of my business the works toilet bowl cleaner is used almost daily in tile and stone showers with no problem. We do not and I dont advise letting it have any dwell time as we apply and remove.
The "works" is 20% acid so its very easy to see what can happen if you dont use it fast.
Bob Foster
Good to know because I'm not sure where acids of this type are safe to use and where their not. Maybe someone can enlighten us.
Larry B
Larry Burrell
The only problems we have had with this are
it reacts to soap scum (put on a mask & eye protection)
If its put on chrome for more than a few seconds it will streak the finish. (dont use on metal)
