Brian H
- Joined
- Dec 14, 2006
- Messages
- 3,755
- Name
- Brian H
It was thrown out of course.I wonder how the chicken tasted?
After he bit into it, I'm guessing.It was thrown out of course.
Someone else there noticed what he was using and they tossed the chicken.After he bit into it, I'm guessing.
You sure know how to ruin a good story.Someone else there noticed what he was using and they tossed the chicken.
Are you sure they didn't install dining room placemats?View attachment 124351
Ive cleaned these stairs a few times. This was the first with the PMF 1530dbl, with the Hybrid Greengle. I use it mostly without the glide, but the glide is a must here.
SameI would have used an upholstery tool...
Takes 10 times longer than the PMF1530DBL. Only reason to use that would be to advertise longer parked in the driveway.I would have used an upholstery tool...
I did try it in the past. Been there 3 or 4 times, and the same owner owned another house with the same design. Been battling that one too before i got the glide and 1530's. I actually enjoy cleaning them now. That much of a difference. Just sharing my experienceIf you say so...
My first thought as well!I would have used an upholstery tool...
It doesn't seem like you could install that tight enough! It seems like a real slip and fall hazard! Even a tiny bit of movement could cause a fall! Especially if I used that staircase. I'm a clutz on normal staircases, I could only imagine going up and down that every day.View attachment 124351
It is not that bad, but not that good. I only saw it done twice by the same builder. Not a fan myselfIt doesn't seem like you could install that tight enough! It seems like a real slip and fall hazard! Even a tiny bit of movement could cause a fall! Especially if I used that staircase. I'm a clutz on normal staircases, I could only imagine going up and down that every day.
This wand does not lock down. The small surface area of the wand head, along with the breather holes on either side allows to clean without. It does great detail work.
We use this stair wand, best I've ever seen.
