- Joined
- Oct 6, 2006
- Messages
- 116,751
Haven't seen itI've seen his hX daoh
Haven't seen it
Heat exchanger kit
This heat exchanger is designed to be used with a gasoline generator to produce hot water for hot water extraction it can also be used to replace your outdated heat exchanger in your gasoline truckmount It can be easily installed by somebody with basics fabrication skills. Installation requires...greymatterchemistry.com
Tim Yeater is helping ED develope a new HX model
I guess since it has the safety valve it might not end up a s bomb.....HEs failing can cause enormous damage**
but watching that video shows pretty much every TIG welding mistake you can make........he has obviously put some time into learning but I wouldn't have him weld anything important up for me
and if I'm going to buy an aftermarket exchanger it will be from someone I know is covered if it explodes or sprays me with steam
edit: the one above didn't have a proper safety valve....and it isn't Yeaters....just an example
YesWasn't that Albert's one? Previous CD guy?
My question is if you're starting over after 30 years of experience, why are you asking for opinions?
I'm nearing the end! Well, hopefully...Getting lightning to strike twice takes some planning.
Have you started over ?
