Acp
- Joined
- May 15, 2017
- Messages
- 1,093
- Name
- Bjorn Marshall
Ok I gotcha, I think I was confused for a sec.. so your skimming over the grout with your grout bond additive, added to grout
Yeah i do the polishing already for the hard stain removal. I use oneRestore first, if that doesn't work, i break out the makita. I do those things but i focus cleaning more i do restorative..thats what i am trying to get my wife on it..she good at itThere's good money but also the nice thing is that you don't have a lot of $invested or overhead. There's not equipment breakdowns (ok I've burned through a couple makita's)
You can get setup with some utility knifes, flat edge blades, and a vacuum cleaner. Having a makita and various pads helps if you're going to be doing hard water spot removal.
I have a Vapor Steam Cleaner but have done tons of showers/baths before I did have that.
I have never used oneRestore. how does it work for shower restoration work?Yeah i do the polishing already for the hard stain removal. I use oneRestore first, if that doesn't work, i break out the makita. I do those things but i focus cleaning more i do restorative..thats what i am trying to get my wife on it..she good at it
@Acp, yes Super Grout Additive® is used to replace silicone and caulk. You can also skim over existing clean grout.@Jason Pettinato in the videos I got the impression super grout additive was a substitute for silicone caulking on the joints, but you mean your using to skim over grout in shower pans?
The other video it looked like grout bond was used for re grouting the shower completely.
@Mikey P , here’s a tip. Pack those holes first with a thick mix of grout/water as a backer, then mix Super Grout Additive® as thick as possible for the final layer. Have your guys apply more epoxy on this one.Jason my guys tried filling holes left over on a tub enclosure wall from the mollies.
They could not get your product level with the tile surface, it sort of dimple'd in..
Any tricks?
@Acp , get yourself a grout color chart and find the closest color. @Caulkmaster will mix different colors for custom matching. I always save any remaining epoxy as a sample and label them for future reference. Tip: let the remaining epoxy dry in the syringe overnight then remove it for a perfect cylinder core sample like in the pic.1 more question for ya. Say you walk into a new job and your going to skim coat the shower pan or an area and want to match it to the current grout on the walls or theres a color in general you need to match elseware in the bathroom.. what would be your technique for matching the color perfectly? any tricks you can share?
Check it out. I used it for window cleaning too.I have never used oneRestore. how does it work for shower restoration work?
Mike..knife set polyester a better option for hole like that...your not going to get a product rhst has sand in it to towel flush and smooth,
Home Depot, CBP, no longer sell ssanded, unsanded grouts....
The movement is to sell 1 type that replaced both.. its considerably more. However color consists t and don’t need to seal.... use hydrolic cements- cure fast ..
Jason, have you tried with the new type grouts?
Mixing may even be easier,
I’m not a slab guy but I agree that there are polyester products for seams that are better suited.
As for Home Depot no longer selling Custom Building Products Polyblend grout, sanded and unsanded, that is not true! Cement based grout is considered the staple of all grouts and the discontinuation of such is highly unlikely.
Well......truth be told...... looks like you might want to follow up with trends in your field.
You must mis read my post Jason....it’s a hydrolic based cement.. what we used to use in my former life for under water repairs on concrete pipes.
Think of it as grout on steroids.
And yes-FACT- our local HD stores only sell this as your only option for cementitious based grout. I’m sure you still go to website and get it....
Simple economics... and long overdue.....why carry 2 of every color...
The Mapei. Version of the same (FX) however will scratch polished TML
Be aware. Being waterproof is a double edge sword..
That’s why caulk fails. Not because it is no longer sealing water out, however because it is sealing water in. This causes it to mold/mildew from the inside out. (Baring poor install). And this becomes unsightly.
Have you ever removed the caulking and have water spit out like you just cut a garden hose?
That’s all the trapped water in the wall. And most water pan only go up 12-18”. After that it overflows into the wall cavity.
Grout will allow trapped water to vapor out.
Something to think about
I only post what I have personally experienced.It seems your 30 years has entrenched your shower beliefs.
Two of these, some tile floors, kitchen counters and coming back to install Super Grout in the floor to tub joint.
View attachment 74851 View attachment 74852
You shower guys should try this stuff if you havent yet..
