Fastfoamer chemistry seems interesting.  The cylindrical machine not so much.
Hot Water extraction vs Fastfoamer video, ok.
How bout a video comparing Fastfoamer, Orbot, Cimax,
CRB, Whittaker, 175 using only FastFoamer for all the machines.
Then another video with the exact machines mentioned above but comparing Fastfoamer chemistry to other encap chemistries.
Its fair to ask…Since this is a revolutionary industry changing system why not the comparisons.
My apologies if comparison videos have already been done.
Rotary is not in the same class as a
CRB machine. Specifically the CCI/
CCA TM 4 (15") & 5 (20"). The
CRB is a "
mechanical entrainment system©" instead of air or water as "fluids" the brushes mimic a semi-solid fluid, a quasi-fluid if you will. It's not that you've been lied to, I just don't think they understood at the time, however have since realized it and now they're "precious" power structure is threatened. As Jim mentioned his 50 years. Yes, the wounds and pain runs deep for these veterans who forged forward, particularly the WRE Truck mount community. You have to understand the history to know how we got here. Look, Jim P. and others aren't particularly bad or evil, they are playing their part. It is up to us to introduce chaos for change. They will resist, however light TRUMPS over darkness. The light will always reveal the truth! ALWAYS! Even in the darkest times of human history, the light always disinfects and brings order to a broken system. Believe my friend, I live and breath it everyday!
Rotary has been know to be bad since the 80's. Dr. Michael Berry has it in his book, protecting the built environment: cleaning for health published in 1993. Do you think he did all his research in less than three years to put this book together? Shaw posted in 2003 rotary was prohibited. Even though the CRI said that rotary was "prohibited" they still continued to test. Why? Then the manufacturer blames who? YOU! Stop dancing like a puppet! It's a joke! Want to hear another.
The manufacturer recommends water rinse extraction with no disclaimer or moisture level recommendations and as soon as there is a dimensional stability or other issue, they show up and say... Ah, you used "
too much water", it's the cleaners fault because that's what it says right? By the very nature of the WRE method, over wetting is inherent and not the technicians fault. Can the tech mitigate wicking and wick back, sure, but they can't stop it. Particularly if someone is telling you pressure and flow need to be high. Muscling compacted soiling, grease and oils is not general carpet cleaning or maintenance. They use carpet in these environments because of carpet's "
maintenance trade-off value©". Putting it in environments like restaurants is worth the extra cost because of noise reduction, safety (slip and fall), etc. This would generally fall under "
ramifications of specification" or "
cost of ownership" but environments like this understand the value carpet has over all other flooring types.
for "effective cleaning to occur" is to occur. It is either Vacuuming (air) solo. Second level of intervention is Vacuuming +
CRB (mechanical) w/ chemical = effective and the final level of intervention and the highest is Vacuuming (air) +
CRB (mechanical) w/ chemical + WRE (water). The moisture level is determined by the entrainment method. VLM, LM and High Moisture. VLM doesn't need to be powder, it can be "
Traditional Encapsulation Extraction©" although I'd say it is for dry
compound peeps unless just "pile lifting" via traditional application. This is the original Whittaker model and they still promote it today as first introduced. I call it the "blow and go". Not cheapening it. This is primarily pile lifting with the single or dual fore and aft passes.
So, here's how to determine if a method or equipment is acceptable. Is it effective? How effective is bonnet (pad)? It's the least effective method, absorption. How is it efficiency wise? Not good. It's absorption and pads need to be flipped every 100 sqft and changed every 2oo sqft. So, 10 bonnet (pads) need to be laundered after a 2,000 sqft maintenance job. Does it "maximize" soil removal? No, we just covered it's the least effective. Does it minimize damage? No, it does not minimize damage. The
CRB removes (extracts) the entangled, trapped and embedded dry soils vacuuming can't remove. NO WRE cannot either. Your box filter with paint filters is not proof. All methods remove soil, but we go by effective and efficient. A set of
CRB brushes ($200) last around 1,000, 000, 000 sqft. Can you say that about bonnets? Let's work that cost up as well. When you add everything up. You could have bought a Carpet Cleaner America TM package that includes debris trays, etc. and the cost would be the same or less. Particularly if you look at some of the more fancier rotary types.
Again, I'm really trying to help here. I know there are people out there that care. I'm not selling anything. I don't want anyone to look at the Fast Foamer system that it doesn't help or improve their value. If you are all about muscling grease and oil off carpets. No problem. I totally get it. I'm not hating on you. That's your market. You think I'd be talking Fast Foamer if I was in that type of market. It's cut throat, dabbled in it and didn't like it. Don't take offense because I know you are hustling! I champion you and support you but we can't lie about the science. It is what is what it is. Carpet is just that valuable. Think about that. If carpet couldn't do what it does because of it's "m
aintenance trade-off value©". Would there be $100K TM units required? Everything has its place.
I'm going to reveal everything! Then you and others will be able to make truly informed decisions and not be herded like sheep.  The fist thing out of a persons mouth that advocates for rotary and says... "its about training". That should be your first clue that someone is ignorant, stupid or just straight out lying!
Regading chemistry and how it works. I can go as deep as you want on the technical side, however I'll keep it simple and no, I'm not being simple to treat you like a child. It took me time to get here and it's all about the "one pager". Condensing the science into smaller digestible chunks.
WRE is achieved using heavy surfactant and co-solvent formulations. The surfactants are for emulsifying the dry-solvent soils (organic soils) and the co-solvents helps breakdown (dissolve to some degree since it can't be saponified) the grease and oil down into smaller components so the surfactants can emulsify the grease and oil, you know this as suspension. However, true suspension is micro particulate 10 microns or less. And dissolving, we know what that is, water soluble soils. Now, for dry-solvent soils that are heavy, aka heavy organic soils aka compacted soiling may require thermal heat to change the state of the grease to make moving it easier. This is where temperature/ heat comes in. So, the water is loaded with "thermal energy" then mixed with surfactants for TM systems correct? However, this is a very inefficient energy transfer system because that is what you are doing. You heated the water and applied it so the thermal energy would transfer to the grease and oil to make it easier to "move" aka remove. Since it's so inefficient with preconditioning, but that is when heat is needed right? Heat falls under the "mechanisms of effective soils suspension", so what's the deal?
The deal is, the power or heat is at the tip of the wand on demand. This is why WRE TM muscle the grease and oil of the carpet instead of trying to achieve "effective soil suspension". I'm not going to say it now, but I bet even the most experienced TM person on this forum can't answer this question or we wouldn't be having this conversation. You have to know that "physics" TRUMPS chemistry! There is an order, a hierarchy of intervention if you will. Whoever wrote the "principles of cleaning for textile floor coverings" wrote it based on "wet" cleaning. Again, another clue. Water = Washing. Start there and work your way through the advancements in the industry and you'll find the answer on how we went from "washing" to "cleaning". Ask, How do we reduce water usage? How do we "wash" aka "clean" more effectively? C'mon. I've provided a ton of clues. Think! I know we can figure this out.
Encapsulation formulas. These can't have high surfactant concentrations due to crystallization. It disrupts that and a very precise balance of surfactants and polymers make up the formula. Surfactants don't aren't just "wetting" agents. They are cleaners/ detergents, dispersants, foaming agents, etc. This means we have limited cleaning power which we all agree. So, what happens here is. The water (universal solvent) is "conditioned" or changed by adding the surfactants and polymers. Now the water has "elasticity" and can hold shape like bubbles. Air is sent through a sinter (mixing medium) that essentially "splits" the air and both captured by the liquid retaining the air which is "energy". The tinier and more polyhedral shape allows the bubbles to be packed really tight harnessing more energy. When this is introduced into the fiber
matrix. It's instant movement unlike liquid systems. The foam allows an exponential exposure of surfactants and polymers. This is NOT effective on compacted soiling, particularly heavy like restaurants. Again, this is for the general commercial environment. It can handle water-soluble and solvent-soluble soils that are light and some moderate. But this isn't for movie theaters, arcades restaurants, etc. Truck mounts have their place. WRE has its place.
So, WRE can have high thermal or just use 60-75 degree water in most commercial built environments. Don't look at temperature as, I can feel it, it's cold water. Look at it from a chemistry perspective and look at where 60-75 degrees water falls on the Kelvin scale. Tap water has plenty of thermal energy to perform effective cleaning. It's not even needed for restaurants. It can be achieved much more effectively and efficiently with chemistry and mechanical agitation than wand stroking it. Again, not neccesarily "wrong" but wrong if no mechanical agitation (
CRB) is used,
sequencing or "
adaptive synergy©" aka "
adaptive cleaning©".
I've got the Fast Foamer system side by side a box extractor with grandi groomer agitation, box extractor with
CRB agitation and others all video. I don't skimp!  I know how to clean. I only used a grandi groomer because that's what is used if anything. My buddy in the video grandi groomed for agitaiton just for show. He wouldn't have agitated in the field. I trained him. I understand why he doesn't want to run a
CRB, but at least he knows what he is trading off or not removing. This is the point. If you know, just say, Steve I don't get paid for that. Got it, no worries. Let's just not continue to spread misinformation. I get this business like no other. Well, here are those that know more than me and that is who I seek. These people are few and far between for me. The higher I go, the more I see I have to learn. Do you see what I see?  Exactly.
The
Dunning-Kruger effect is a cognitive bias where people with limited knowledge or skills in a specific area tend to overestimate their own competence, while those with expertise may underestimate their abilities.
What it is: The Dunning-Kruger effect describes a situation where individuals, lacking expertise in a particular area, mistakenly believe they are more knowledgeable or capable than they actually are.
Why it happens: This bias stems from a lack of metacognition, or the ability to accurately assess one's own knowledge and skills.
The opposite side of the coin: Conversely, individuals with high expertise might underestimate their own abilities, believing that the task or knowledge is simple for everyone, when in reality it is not.
Example: Someone with little experience in commercial carpet cleaning might confidently claim they could easily clean a complex soiling situation, while a seasoned cleaner might hesitate to take on a job they perceive as too simple.
Hope this helps. I won't be posting much as this is a distraction. As you can see unless it get's taken down and censored. The establishment doesn't like being challenged. Me on the other hand. It only proves my point and makes me stronger. They know my light,  not only shines but burns too bright for them to control or extinguish. S0, they end up acting like petulant child. As if someone "licked the red off of their candy". I'll share more but the
IICRC and CRI need to get right!
