Bryce C
DFW
- Joined
- Feb 9, 2024
- Messages
- 1,377
- Name
- Bryce
name for a carpet cleaning business you have ever seen? Aside from mine...
Mud Making Carpet & Upholstery Cleaning!name for a carpet cleaning business you have ever seen? Aside from mine...
You obviously don't know anything about the Bane Clene?They must have been using a Bane Clean. At least they had the integrity to fairly warn their customers.
First, you have to give the stupidest200 psi?
Their equipment didn’t put out more than 150psi
If you cranked it any higher you blew the stator
Bane didn’t use a pressure pump… they used a sludge pump
Only way to increase flow and impact was to throw 2 #3 jets into an S Bend wand
water plus dirt equals mud..You obviously don't know anything about the Bane Clene?
Pretty hard to make mud with 200 psi's {it can be done}
TM guys,water plus dirt equals mud..
Confucius, once saidFrank is the one that is deficient of his knowledge regarding Bane Clene equipment
People that speak the most often have the least to contribute
I would run my three Bane units between 135 and 200 psi for years200 psi?
I do not understand your obsession with the premise that HWE wets the back of the carpet and pad when performed properly.TM guys,
Seem to find it somewhere between foam padding and the backing of carpet![]()
Because most TM guys over wet carpet just a fact Jack I mean Jeff.I do not understand your obsession with the premise that HWE wets the back of the carpet and pad when performed properly.
I think I've done just about all I can do in the Carpet Cleaning world? Mostly everything?Maybe you should expand your horizons.
From your point of view.Matts
