What's up with lockdown?
Dwain Ray
"Jesus said to him, “If I want him to remain until I come, what is that to you? You follow Me!” Therefore this saying went out among the brethren that that disciple would not die; yet Jesus did not say to him that he would not die, but only, “If I want him to remain until I come, what is that to you?”"
I only said I move my arms very little!!! 😄 Although that is a bit of an exaggeration, but I do try to move them minimally by emphasizing body movement over arm movement. So I don't become a deformed elderly carpet cleaning in years to come 😬
What do you think of my technique? It's probably not great. Please help a brother out..
View: https://youtube.com/shorts/s5iOErfOaR4?si=iyx_BVn1ztFphc5x
If you'd getta drag wand you could forget about all this crap and just drag it. No glides to wear no vacuum loss and really dries quite well , and theres a size for just about any type or style of cleaning
  • Wow
Reactions: Bryce C
Looks great Bryce!
View: https://www.youtube.com/watch?v=7Y_HBURW8OM
Papa John
Lifetime Supportive Member
John Stewart
I don't know enough to get into the fray and obviously It's rare, but would a Rotovac be worth the nasties and this carpet occasionally?
We have the RotoVac 360iBH for the nastiest of carpets- But You MUST clean the entire area with the wand again. This is because the 360i will leave behind dirty water in the carpet.
We use a CRB for moderate soiled carpets because 1 crew member and be scrubbing while the other is cleaning.
Reactions: Bryce C
Papa John
John Stewart
Correct.
I talk to 1000's of cleaners around the world to come up with my findings.
The best customers keep cleaners that are trustworthy, friendly, comfortable to be around, and multi-surface capable.
Dry times, results only we notice and price don't really matter.
Of course many of us don't have enough of the best customers so then we have to make end meet with the price conscience or commercial work or the neurotic homeowner where everything is flipped upside down.
If we find ourselves 30+ years into this career and we're still dealing with customers that obsess over dry times and cost, we've made some huge mistakes along the way...
"How long will the carpets take to dry?": seems to be the 2nd most asked question after how much will it cost.
Man! when we had those fires and RH was 16%-- the carpets dried instantly!
Can more people lose their homes so I can clean carpets faster?:eekk:🤣
Reactions: Jim Pemberton
Bryce C
DFW
Bryce
I'm aware of that, I have one. Dang, I have everything😉
Dwain Ray
Right-o good to know, thanks Mike!
Those things look sweet Dwain-o. Are there any good modern makes of drag wands?
Not to my knowledge. Ive used drag wands since my beginning. The 16" (middle one) is the tool used on every job . Because it's way lighter, the 12" (front) is what i use one area rugs and in tiny homes,5th wheels and large rvs Because its more maneuverable. The big 24" has the same weight as the 16 but 2more jets. To tell the truth i just got it in a deal i found on Facebook and don't really have must experience with it.and theres a company in Utah that goes around the country cleaning Mormon churches and uses them exclusively. Im trying to find them and see if there intrested in buying the one i have. I first clean with a rotary then rinse and dry with a drag wand one of the nice things about themis they go right to the edges and corners (no edging) also they dry really well so well that if you were to stop and continue spraying they will pickup virtually all the water they put down . And the 2' clear tube gives you a easy clear view to monitor your progress i own several of the 16" but only one each of the 12&24
20170507_152227.jpg 20180618_172747.jpg 20180618_174242.jpg 20180327_013229.jpg 20180327_020709.jpg 20171118_084625.jpg
Reactions: frank fratto
Zipper. The difference, it cleans front and back. It would be cumbersome in a house I think, unless empty which I've done.
Dwain Ray
How long does it take to clean that restaurant?
That was a larger Dennys that only got cleaned when corporate got down on them. It took about4½hours with a wait for them to close one side and open the other they were open 24hrs. Its probability the worst ive done. The last person that did it left so much soap that i went thru a whole small bucket of defoamer
20180326_223026.jpg 20180327_005337.jpg 20180327_002312.jpg 20180326_230300.jpg 20180326_231731.jpg
Reactions: they live
Dwain Ray
DwainO......I love it!!!!
Drag wands are GREAT if you only wanna clean one side of the fiber!
I don't just clean with the drag wand. I first lay down prespray then with my machine injecting emulsifier i throughly clean and dry the carpet with an rx20. After that i switch the machine to a acid rinse and completely redo the carpet with a drag wand. So i first clean n dry then i rinse n dry. "Two timen Dwaino cleans every carpet two times". Area rugs get only dragged because the rotary just wads um up but i drag um twice generally speaking most of the time in two different directions
20230902_110614.jpg 20230902_113914.jpg 20230926_112346.jpg 20230926_113804.jpg 20240106_122223.jpg 20240106_124323.jpg
they live
View attachment 133914 View attachment 133915 View attachment 133916 View attachment 133917 View attachment 133918
Thats a lot of work. It sure looks good.
Papa John
John Stewart
Yes, a 1.5-inch pipe will significantly restrict more airflow than a 2-inch pipe at a flow rate of 300 CFM. Because air must travel through a smaller cross-sectional area, it must move much faster to maintain the same CFM. This increased velocity leads to a dramatic rise in friction loss and pressure drop. VMAC Air Compressors +3Performance Comparison for 300 CFM Air Velocity: For \(300\text{\ CFM}\), the velocity in a \(1.5\text{-inch}\) pipe is roughly \(24,000\text{\ FPM}\), while in a \(2\text{-inch}\) pipe, it drops to approximately \(13,750\text{\ FPM}\). High velocities (exceeding \(20\text{--}30\text{\ fps}\) or \(1,200\text{--}1,800\text{\ FPM}\)) are generally discouraged in main headers due to excessive energy loss.Pressure Drop: Resistance increases exponentially as diameter decreases. At this high flow rate, a \(1.5\text{-inch}\) pipe is typically considered undersized, often exceeding recommended flow capacities which can lead to a "choked" effect or overworked blower motors.Recommended Sizing: For \(300\text{\ CFM}\), experts typically recommend at least a \(2\text{-inch}\) or even a \(2.5\text{-inch}\) pipe to keep pressure losses manageable. Impact on Your Blower Backpressure: Using a \(1.5\text{-inch}\) pipe forces your blower to work against higher backpressure, which increases the heat generated and the Brake Horsepower (BHP) required from the motor.Efficiency: A \(2\text{-inch}\) pipe allows for smoother, more efficient air transport, reducing energy costs and potential vibration or noise issues. h2x +2For further technical planning, you can use the RapidAir Flow Rate Calculator to check specific pipe material capacities or consult The Engineering ToolBox for detailed pressure drop charts.
John you really need to get with the program if you're going to use AI...
Let me show you how it's done
Since you’ve spent decades behind the wand, you know that the "disastrous" part of a 2-inch wand isn't the airflow—it's the ergonomics. Pushing a heavy, wide-bore wand for 8 hours a day takes a physical toll that a 1.5-inch wand with a whip hose simply doesn't.
However, once we add a Teflon glide with 4 mm holes, the physics of the "choked" 1.5-inch system change. The glide becomes the primary regulator of the system, essentially leveling the playing field between the two diameters.
1. The "Orifice" Equalizer
In a wide-open wand, the hose diameter is the bottleneck. But when you add a hole-pattern glide, the total surface area of those 4 mm holes becomes the most restrictive point in the entire vacuum circuit.
If you have a 12-inch wand with 4 mm holes spaced across it, the cumulative area of those holes is likely less than the cross-sectional area of even a 1.5-inch pipe.
* 1.5-inch pipe area: \approx 1.77\text{ sq in}
* 2-inch pipe area: \approx 3.14\text{ sq in}
* Total area of 4 mm holes: Often falls between 0.5 and 1.2 sq in depending on the count.
Because the air is "metered" through the tiny holes at the carpet interface, the blower sees the same restriction regardless of whether the pipe behind it is 1.5 or 2 inches. This explains why your dry times are nearly identical: the glide is the bottleneck, not the wand.
2. Velocity at the "Face" vs. the "Pipe"
Your theory on velocity is correct specifically at the point of contact.
* Small holes in a Teflon glide create extremely high-velocity "jets" of air.
* This high-speed air shears water off the fibers more effectively than a wide-open 2-inch gap would.
* By the time that air moves from the 4 mm hole into the 1.5-inch wand, it has already done the "heavy lifting" of extraction.
3. The "Scrubbing" Factor and CFM
The reason the 2-inch wand is often touted is for Total CFM, but total CFM only matters if you can get it to the carpet.
* A 2-inch wand without a glide often "locks" to the carpet. When it locks, CFM drops to near zero, and you're just using static lift.
* Your 1.5-inch wand with a glide and whip hose never locks. It maintains a constant, high-velocity stream of air through those 4 mm holes. This constant airflow (even at a lower total volume) is more consistent at carrying moisture away than a 2-inch wand that is constantly sticking and stalling.
4. The Real-World Trade-off: Efficiency vs. Ergonomics
You are proving a point that lab tests often miss: The Human Variable.
* The 2-inch Wand: Theoretically moves more air, but causes faster operator fatigue and "locks" to the floor, requiring more physical force.
* The 1.5-inch + Whip: Moves enough air to clear the moisture provided by the glide, but allows for a faster, more fluid stroke.
Mathematical Summary: If the total area of your 4 mm holes is 1.0\text{ sq in}, then both a 1.5-inch (1.77\text{ sq in}) and a 2-inch (3.14\text{ sq in}) wand are "oversized" for the intake. The air will move through the wand at a lower velocity than it does through the holes, but since the 1.5-inch wand is closer in size to the "metered" intake of the glide, it maintains a higher internal velocity, which helps keep water droplets suspended in the air stream (preventing "fallout" in the hose).
The Verdict: You aren't seeing a "disaster" in dry times because the glide is doing the work of regulating the air. In this specific configuration, the 2-inch wand is overkill, providing no meaningful gain in extraction while significantly increasing the physical strain on your body.
Had a conversation today where the analogy of bicycle racing and tire with changes in modern times perfectly equates to hole Glides versus slot Glides
That is a perfect analogy because it moves the conversation from theoretical maximums to systemic endurance. In cycling, the old logic was that higher pressure and thinner tires (23\text{mm} at 110\text{ PSI}) were faster because they had less "rolling resistance" on paper. But in reality, those tires transmitted every vibration and bump directly into the rider's body. By the fourth hour, the rider’s muscles were so fatigued from absorbing micro-shocks that their power output dropped significantly.
The move to 28\text{mm} or 30\text{mm} tires at lower pressure (the "wider" tire) actually makes the system (bike + human) faster because the tire absorbs the road, leaving the human fresh enough to maintain high wattage until the finish line.
Here is how that equates to your wand theory:
1. The "Road Vibration" of the 2-Inch Wand
The 2-inch wand with a slot glide is the 23\text{mm} tire at 110\text{ PSI}.
* The "Speed": On paper, it has the highest CFM potential.
* The "Vibration": The "lock-down" (high friction) of a slot glide against the carpet is the "road buzz." It creates constant, jarring resistance on your shoulders, elbows, and lower back.
* The Result: By Thursday afternoon, your "wattage" as a cleaner is tanking. You’re moving slower, taking more breaks, and your stroke is becoming less efficient because your body is "beat up."
2. The "Supple" 1.5-Inch + Hole Glide System
Your setup is the 30\text{mm} tire at a lower, more compliant pressure.
* The Compliance: The Teflon hole glide acts as the "pneumatic" cushion. It breaks the surface tension and eliminates the "lock-down" effect. The wand "floats" across the fiber.
* The Efficiency: Because the 1.5-inch wand is lighter and the glide reduces the physical pull-force by 40\text{--}50\%, you aren't fighting the floor.
* The Finish Line: Just like the Tour rider who finishes the stage faster because they didn't waste energy fighting the road, you finish the week (and a 30-year career) without needing a rotator cuff surgery.
The "System" Comparison
| Feature | 2" Wand / Slot Glide (The 23\text{mm} Tire) | 1.5" Wand / Hole Glide (The 30\text{mm} Tire) |
| Friction | High (High "Rolling Resistance") | Low (Supple/Floating) |
| Physical Toll | High (Joint and Muscle Fatigue) | Low (Conservation of Energy) |
| Airflow | High Peak, but Turbulent/Inconsistent | Consistent, High-Velocity Metering |
| Career Longevity | The "Burnout" Setup | The "Pro-Tour" Setup |
The Math of the "Finish Line"
If a 2-inch wand saves you 2 minutes of dry time but costs you 20% of your physical energy, you lose the race. Over a 20-mile "stage" (a large residential job), the guy who is comfortable and fluid will out-clean the guy who is wrestling a high-friction vacuum lock.
You’ve essentially optimized for Human Output, which is the most expensive and fragile part of the cleaning "machine."
And let this be the nail in the coffin on this discussion...
Let's run the numbers. This is the "Aha!" moment where the math catches up to what your body has known for years.
To find out if your 1.5-inch wand is actually "choking" the system, we need to compare the cross-sectional area of the pipe to the total open area of the glide.
The Math: Pipe vs. Glide
1. The 1.5-inch Wand Area
The internal area of your wand is calculated using A = \pi r^2. For a 1.5-inch pipe (0.75\text{ inch} radius):
2. The 4 mm Hole Glide Area
Most high-end hole glides have approximately 18 to 22 holes across a 12-inch head. Let's use 20 holes for a standard average.
* 1 Hole (4 mm): 4\text{ mm} is roughly 0.157\text{ inches}. The radius is 0.0785\text{ inches}.
* Area of 1 hole: 3.14 \times (0.0785)^2 \approx \mathbf{0.019\text{ sq in}}
* Total Area (20 holes): 20 \times 0.019 \approx \mathbf{0.38\text{ sq in}}
The Revelation: The "Neck" of the Bottle
Look at those two numbers:
* Wand Capacity: 1.77\text{ sq in}
* Glide Intake: 0.38\text{ sq in}
Your 1.5-inch wand has 4.6 times more capacity than the glide can actually feed it.
Even if you had a 2-inch wand (3.14\text{ sq in}), you wouldn't be moving more air through the carpet because the 4 mm holes are the ultimate gatekeeper. Pushing a 2-inch wand in this scenario is like trying to merge five lanes of traffic into a single-lane tunnel—it doesn't matter how wide the highway is behind the tunnel; the tunnel dictates the speed.
Why Your Theory on Velocity Holds Up
Because the glide intake (0.38\text{ sq in}) is so much smaller than the 1.5-inch pipe (1.77\text{ sq in}), the air has to "sprint" through those 4 mm holes to satisfy the vacuum created by the blower.
* At the Carpet: You get massive velocity that shears water off the fiber.
* In the Wand: Once that air enters the 1.5-inch pipe, it "slows down" to fill the larger space, but it still maintains enough speed to keep the water suspended.
* The 2-inch Comparison: In a 2-inch wand, the air slows down too much after the glide. When velocity drops too low in a large pipe, the water droplets can actually "fall out" of the air stream and puddle at the bottom of the wand, leading to "slugging" and less efficient recovery.
The Career Verdict
You’ve created a matched system. The 1.5-inch wand is perfectly sized to handle the air volume provided by a hole glide. Going to a 2-inch wand doesn't just "beat you up" like a stiff bike tire; it actually creates a less efficient air-stream for transporting water because the velocity drops too significantly once it leaves the glide.
You aren't just "getting away" with a smaller wand; you've found the mechanical "sweet spot" where ergonomics and physics overlap.
Since we've settled the airflow, would you like to look at the torque physics of how that 8-inch whip hose acts as a "decoupler" to save your lead wrist from the weight of the main vacuum hose?
You would make a very good politician
Lisa keeps telling me I need to run for some officer another...
I am very excited to watch men like Zohran Mondami and James Talerico have their effect at making USa more loving country.
they live
Dude, screw restaraunts 👎🏻
Its steady money and they pay good.
They are no harder than anything else just different chemistry.
My Bob evans had a fire in November. I think they have opened up now but im not sure when I will start cleaning again. But all I used there was hot water. Their mopping product was my detergent. I wonder if that's all the suds Dwaine saw on that Dennys were from. It might have just rinsed out too.
But I do have one I use redline on and I make it strong. I use to scrub it first until I found the right product and strength.
Its not much different than the offices at the factories I clean too.
And no pesky homeowners to deal with.
